How I can call a SPI function from Interrupt service Routine
Hi
I am using 89C51ED2 for my projects.From SPI I am receiving datas from peripherial.I using inbuilt registers like SPDAT,SPCON.But I can't call my SPI function
from interrupt service routine
My CODE is
void readspi(void){
Enablecs();
SPDAT = addr;
while((SPSTA & 0x80) == 0);
spivalue = SPDAT;
Disablecs();
void Ext0_ISR(void) interrupt 0 using 1{
readspi();
void main(void){
static unsigned int spivalue;
while(1){
Please help me to over come this problem
  • "I can't call my SPI function from interrupt service routine"
    Why not? Please explain precisely!
    BTW: Note that you ISR uses Register Bank 1; your readspi() function would need to use the same bank...
    Is readspi() also calle from non-interrupt code?
    If not, why make it a separate function?
    Note that having wait loops in an ISR (or called from an ISR) is generally not a Good Thing.
    Note also that having wait loops with no timeout or other "emergency escape" mechanism are definitely not a Good Thing - sooner or later, your code will hang in one of them!
