uVision generates no hex- file, although I have set the Option in Options - Output. I haven't found any other configurations I have to select in the help, so I don' t know what' s wrong.
Are you sure you're looking in the right folder? Does the build succeed otherwise? If you have build errors, there will be no hex file!
check out option settings.
