I'm using Keil Arm eval & XP SP2. Sometimes when I plug in the Ulink adapter to the USB the PC crashes with a blue screen. The PC then resets so I can't see what the message is but I've seen USBPORT.SYS in there. I'm using keilul.sys v2.00. Has anyone seen this or know what causes it ?
You may turn off the auto reboot in the system control panel Thomas
I too have this problem with the blue screen. I also do not have Auto reboot turned on. Sometimes the Keil debugger just hangs and if I unplug it, the debugger comes out ok. I can then continue, but if I plug the ULINK back in, the system crashes with the blue screen. I am also using 2.0 version of the driver.
Maybe you just need a lucky black cat to go with your uLink: http://www.antronics.co.uk/images/ulink_cat_lo.jpg
