when debug then go! if you want to display chinese.....you'll find it doesn't display chinese correctly! because keil's serial display is single byte.but chinese is two byte ...you must fresh and fresh!
You may use the ASSIGN command and use an external terminal emulation that handles your character set. See: http://www.keil.com/support/docs/2602.htm
I know this method! but I think if keil correct this bug will be fine.
I know this method! but I think if keil correct this bug will be fine. How can it be a bug that a program works as specified??? Erik
