hi all, I am using xc866 infineon processor.I want to generate .hex file using command prompt option.Is it possible in Keil Thanks in advance, Chris
uVision can create a BATCH file from a project file. See: http://www.keil.com/support/docs/2594.htm Also the tools have a command line invocation. See: http://www.keil.com/support/man/docs/c51/c51_cm_comppgms.htm Reinhard
xc866 infineon processor. wat dat I know of the Philips 866, but not Infineon and it is not in the Keil database. Has Siemens started second-sourcing the 866? Erik
http://www.keil.com/dd/chip/3844.htm
