Linker problem with gcc toolchain and optimisation
i'm using a an lpc2119 device with gcc toolchain.
everything works fine, except when i set the optimisation level to anything other than -O0
(ie i try to apply any form of optimisation)
then i get a linker error which is "section .rodata.str1.4 [...] overlaps section .text[....]"
which seems to imply that the string table is not being correctly allocated (?)
any ideas will be much appreciated!
