I have a "button" task that receives button down and button receive events. I want to distinguish between short and long button presses. This works the first time; the second call to os_evt_wait_and correctly detects a timeout while waiting for the button release event. However, the second time around, no timeout is detected because the button release event fires right away. while(1) { // Clear any previous events. os_evt_clr( BUTTON_DOWN_EVENT, gButtonTaskID ); os_evt_clr( BUTTON_RELEASE_EVENT, gButtonTaskID ); os_evt_wait_and( BUTTON_DOWN_EVENT, INFINITE_WAIT ); result = os_evt_wait_and(BUTTON_RELEASE_EVENT, 5000 ); //LEDSetup( 0, 0, LED_COLOR_OFF, LED_HOST_COMM_MODE ); // Stop the bluetooth setup task if running. if( gBluetoothSetupTaskID != 0 ) { os_tsk_delete( gBluetoothSetupTaskID ); gBluetoothSetupTaskID = 0; printf( "bluetooth task stopped\n" ); } switch( result) { case OS_R_EVT: // Button was released within 5 sec. printf( "Short button press\n" ); break; case OS_R_TMO: // Button pressed longer than 5 seconds. break; default: break; } } // end of while loop
