Hi, We want use the AGSI Watch Memory functionality to access a variable in the area between 0xE00000 to 0xE007FF. We have written a sample program for Infineon XC164CS with AGSI memory watch for variables at address 0xC000 and 0xE00702. For the variable at address 0xC000, we are able to get the control to the DLL. For the variable at address 0xE00702, we are NOT able to get the control to the DLL. Could any of you suggest a method inorder to solve this issue. Regards Srinivasa Reddy
Before the Agsi.SetWatchOnMemory function can be used to define a callback function for memory accesses, the memory area must be mapped. Your code in the AgsiEntry function may look like:
if (!DefineAllInterrupts()) return(FALSE); // define all interrupts Agsi.ExecuteCommand("MAP 0xE00000, 0xE007FF READ WRITE EXEC"); if (!DefineAllWatches()) return(FALSE); // define all watches
