Hi, i need to use read and write .xml fimes in my µvision program. how can i do this? Thanking you.
You have now had 2 independant suggestions to generate 'C' source files. This is the approach taken by Code Architect. Why don't you give Code Architect a try; eg, http://www.codearchitect.org/philips/v2/index.php?co_tree=89LPC901%23Watchdog Having seen what it does, if the approach is not suitable then please explain why not. Note: I am not suggesting that Code Architect is the solution to your requirement; I am suggesting that the approach used by Code Architect (ie, generate 'C' source) may be suitable...
Don't keep starting new threads on the same subject! http://www.keil.com/forum/docs/thread7057.asp http://www.keil.com/forum/docs/thread7044.asp You can't start processing XML before you've got the basics of reading a text file! It is still unclear what exactly you want to read from this file, and what you want uVision to do with the data that it reads!
