I don't know why timer 0 is not running when PS flag of serial port is set
Post the smallest complete piece of code that illustrates your problem. Remember: use cut-and-paste; do not manually re-type. Also remember to use the 'pre' and '/pre' tags, as explained in the Notes immediately above the Message box when you make your post. http://www.keil.com/forum/tips.asp
