I am having a slight Problem with the putchar function . when i say putchar(0x0A) it put 0x0D & 0x0A both but i only need 0x0A i tried writing putchar myself but dose not seem to work what i did was void putbyte(char mydata) { while(!TI) { TI=0; SBUF=mydata; } } please point out the mistake and any other way to solve my problem
Well.. you called it 'putbyte', amongst other things. If you are trying to replace the default putchar() so that it'll work with printf() and so on you need to do something like this: char putchar(char c) { while(!TI); TI=0; SBUF=c; return(c); }
Thank you Stefan Duncanson i will try that , actualy i was not trying to override putchar but to create a same funvtion which will have the same effect while keeping putchar intact. But i willtry it your way thank you again
hi Stefan , I would again like to thank you , as i implemented what you suggested and its working great thank you again Ajay
