FLASH Programming errors
I am trying to create a FLASH programming algorithm for the Intel 28F320C3TC90 FLASH.
I am using the Keil tools as specified in the help section.
I am using the RealView Debug V1.8 as the ARM compiler.
I can compile without any errors. Just warnings about the command line parameters. i.e.
28F320C3TC90.axf: Warning: X0010W: Old syntax, please use '--info'.
When I tried to build the algorithm using the given FLASH.lib I get the following error:
28F320C3TC90.axf: Error: L6242E: Cannot link object Flash.lib as its attributes are incompatible with the image attributes.
Target not created
What is in the FLASH.lib file that might be causing this?
I also tried to build one of the provided algorithms and got the same error.
Is there another way to build a FLASH programming algorithm using the KEIL tools?
