ds89C420 watchdog
hi all,
i've a system with 2 code memories, the internal flash of the chip and an external 29b040.
I've a "forced watchdog reset" function that works if i call it from external flash, but running from internal flash calling same function (copiled as the same in both codes) the reset don't happen.
void WatchdogReboot(void) {
WDCON &= ~0x04; // reset watchdog reset occourred if present
WDCON |= 0x01; // Enable the Watchdog timer
CKCON &= 0x3F;
TA=0xAA; // Accessing timed access in order to start the watchdog timer
TA=0x55; //
EWDI=1;
WDCON |= 0x02;
for ( ;; );
Any help is very appreciated.
angelo
