hi,everybody,I'm using keil7.20,uvision3.and I have an ok project.but when I added _push_(DPH); _pop_(DPH); to my main() func, an err always ocurrs: Build target 'Target 1' linking... *** WARNING L1: UNRESOLVED EXTERNAL SYMBOL SYMBOL: __POP_ MODULE: Main.obj (MAIN) Program Size: data=98.0 xdata=0 code=1730 creating hex file from "reset"... "reset" - 0 Error(s), 1 Warning(s). if move away _pop_(DPH);and everything will be ok;so I'm really confused. I think the to use _push_(); and _pop_(); are same. But what's going on with this? waiting for your help and answers.
It sounds like the linker can't find " _pop_ ". Are the right files being included?
Since the linker is looking for them and we know they're intrinsic, he apparently hasn't included intrins.h.
This problem does not exist with the current release V7.50. Reinhard
guys, thank you for ur replies. But now the situation is: first,I did include the header file: intrins.h in my main.c file. next,It's just ok for _push_(); but _pop_(); has the problem:(,I mean the linker could find _push_(); func prototype,why not for _pop_(); I check the asm file,just _push_(DPH);[PUSH DPH;] there,no _pop_();[POP DPH] at all:(, and what's more faint is: I did nothing ,but just build the target several times. and guys, guess what happened. the warning is still there: *** WARNING L1: UNRESOLVED EXTERNAL SYMBOL SYMBOL: __POP_ MODULE: Main.obj (MAIN) Program Size: data=98.0 xdata=0 code=1730 creating hex file from "reset"... "reset" - 0 Error(s), 1 Warning(s). but the asm code is like this: 112: InitSYS(); // initialize system; C:0x0581 120695 LCALL InitSYS(C:0695) 113: _push_(DPH); C:0x0584 C083 PUSH DPH(0x83) 114: _pop_(DPH); C:0x0586 D083 POP DPH(0x83) 115: SetRxMode(); C:0x0588 1206B5 LCALL SetRxMode(C:06B5) there it is,there POP DPH is!,so what's wrong with the compiler or with me? and thank you for your replies again.:)
