uVision Debugger displaying arrays of Structures
I'm using uVision2 V2.40A.
Please look the following example:
struct structPeriod
	int From;
	int To;
	int x[4];
struct structConfig
	struct structPeriod  Periods[5];
	int x;
	int y;
struct structConfig  Config;
void main()
       while(1)
In the Watchwindow of the Simulator i can see
the array of structures with a '+' sign. But Clicking on the '+' to display the structure,
nothing changes.
Is this a bug or is it a mistake by me?
Thanks for your reply.
Eugen
  • Thank you for pointing out this problem. It appears to be a problem in the BL51 Linker.
    The same works fine when you are using the LX51 Linker/Locater (select under Project - Options - Device). Note that this linker is only available when you have the PK51 Kit.
    Send an email to support.intl@keil.com and we will send you a patch as soon as it gets available.
    Reinhard
    Reinhard
