Hi, all of you. I would like to know how to improve my debuging facilities with uV2 version 2.14? Please suggest me how to get watchdog timer, ADC, DAC, LCD display, LED's on ports for debugging. Thank you.
"You may have to dig a bit to find a version of the code that still works with a uV2 as old as your 2.14, though." Have you checked the latest uVision to see if it already has the facilities you require? It certainly supports those peripherals mentioned for some variants...
See Application Note #154. You may have to dig a bit to find a version of the code that still works with a uV2 as old as your 2.14, though.
