WRONG XRAM VALUES DEBUGGING ADUC847
Hello:
I have a problem while debugging or simulating the analog device microcontroller Aduc847.
When I compile with "Small" memory model, I'm able to watch tha value of all the variables, but If I define the same variables with xdata ( on chip ram memory), with "large" memory model, then the values of this variables have no sense, the seems not to be updated properlly, nothing works fine.
At the options tab I have enabled "use on chip XRAM(0x0, 0x7FF)" and "use on chip ROM(0x0, 0xF7FF)
the code ram size is "Large: 64Kbyte program"
I use keil v7.07
Does anybody have any idea about what's happennig??
thanks in advance
David
p.d.
at the options tab BL51 locate I have enabled also "use memory layout from target dialog"
