Hi, I'm using Silabs IDE and KEIL C51. I need to modify the PUTCHAR.C and to add it in my project. The problem is, in my MAIN.C file I have declared a circular ring buffer (I'm using the buffer for UART transmit) wich is delared: xdata RingBuf rbTX0; // Transmit buffer But in the PUTCHAR.C I'm writing to this buffer. The problem is when I compile I get an error POINTER TO DIFFERENT OBJECT. I have added the putchar.c to my project. So how can I use a variable in a file that was declared in an other file ? Thanks, Aldrin,
xdata RingBuf rbTX0; // Transmit buffer Can't even guess what that is, is RingBuf a structure??? Pray explain. Erik
Hi, yes it is... typedef struct _ringbuf { unsigned char ucCount; unsigned char ucHead; unsigned char ucTail; unsigned char aData[RB_BUF_SIZE]; } RingBuf;
So how can I use a variable in a file that was declared in an other file ? Header (.h) files are used to describe the interface to a module. Data items should be declared with the extern keyword. This header file would then be #include'd in any .c file that wishes to access that data. The item must also be defined -- that is, have storage allocated for it. There should be only one definition for an item. So, definitions (storage allocations) do not belong in the header files, but in .c files. RingBuffer.h: // let the world know that somewhere there exists a RingBuf called rbTX0 extern xdata RingBuf rbTX0; RingBuffer.c: // here's where the RingBuf rbTX0 actually lives xdata RingBuf rbTX0; putchar.c: // I'd like to have access to the RingBuf rbTX0 #include "RingBuffer.h"
Thanks a lot M. Davis ! Everything is working fine and now I understand much better how to deal with mutiple files. Best regards, Aldrin,
