A way use isr_evt_set function by FIQ in ARTX
In the ARTX, since the isr_evt_set can not be use in the __fiq function, I use the __swi function set the task instead. for exampal:
void IsrSetFunction (void) __swi (8) {
isr_evt_set (0x0001, tskMyTask);
void FIQ_Handler (void) __fiq {
IsrSetFunction();
EXTINT = 0x00000002; // Clear the peripheral interrupt flag
But this way will do? You know, the ARTX using the swi to do something.
'Software interrupts 0-7 are used by the Advanced Real-Time Kernel (ARARM) and may not be used in your application.'
So if I use the swi to set a task, this will occur some problem in ARTX?
