SMS interrupt 0{ berita(0x0000,0x3fff); } show interrupt 1{ berita(0x4000,0x7fff); } Interrupt 0 and interrupt 1 call the same sub routine but for different purpose. When compiled, the C51 generated warning L15: MULTIPLE CALL TO SEGMENT Segment : ?PR?_BERITA?RTX Caller1 : ?PR?_SMS?RTX Caller2 : ?PR?_SHOW?RTX The program does'nt work at all if the HEX file programmed to the chip AT89S51. Any one please, How to omit the warning, or to use interrupts calls one sub routine for a different purposes. Thank you very much Kurnia Brahmana
I don't know whether it is possible to suppress that specific warning. You would need to be certain that your function is reentrant for this to work, noting that any functions called by that function would also need to be reentrant. Personally I prefer not to call functions from interrupt handlers at all to avoid any potential mistakes. It may be ugly, but I inline all ISR code.
It may be ugly, but I inline all ISR code. That would depend on the eye of the beholder. I think it is beautiful. Erik
Dear Erik Malund Your suggesion solve the problem, but increase the code significantly. But, I will follow your suggestion if no other way to do. Thank you very much.
