Hi, I am having a while(1){} loop and all interrupt disabled. It loops for a while and then gets out of the loop, jumping to a random address (not interrupt vectors) or break of out the loop and continues sequentially from there. Is there anyway to detect a bad instruction fetch? In other microcontroller, a bad instruction would branch to an interrupt vector. Thanks, Anh
It sounds as though a function call return address is being corrupted on the stack for one reason or another. Can you post some code?
Thanks all, the code is just: while(1){}. I think it's a code memory issue and just trying to recover from it. Anh
