Hi, I am trying to write a program that will perform an action at 30 MHz. I was thinking the way I need to do this is to set a timer that will go off every 1/30th of a second and call an interrupt to perform the action. Does anyone have any example code of how this would be done on an 8051 (ADuC812 specifically) ? Thanks, Todd
Todd; I think you have your math wrong. Your time base (1/30 sec) is about 33.3333Msec not uSec. However, look at App note 105 on the Keil website for an interrupt driven timer example. Bradford
"I think you have your math wrong. Your time base (1/30 sec) is about 33.3333Msec not uSec." And he's not the only one confusing his "milli-" with his "mega-" ! "mega-" is a million (10^6) and is represented by an uppercase 'M'; "milli-" is a thousandth (10^-3) and is represented by a lowercase 'm'. Also, the symbol for the second - the SI unit of time - is a lowercase 's' (uppercase 'S' is siemens, the unit of electrical conductance)
Well I had meant 30 Hz so 1/30th of a second was right. And I found some really good powerpoint slides from some class at U-Texas online so I think I got this figured out. Thanks everyone!
