Hello, I have developed a software using code architect's I2C software and it works fine when I use the EPM900 emulator. However, when I burn it into a PLC932, it works sometimes and when I add a little code to it or change some statements around, it stops working. The program size is 2200 or so bytes and I do not exceed the data and xdata limits of the chip and all variables are being initialized. Can anyone think of what I am doing wrong? I would appreciate any hints. This thing is driving me crazy! Thanks.
emulator works, chip doesn't usual causes: a) Clocking (if internal to ICE) b) Resets c) power and ground e) configuration (if I remember, there is something about the EPM900 killing PushPull) and the IIFC pins MUST be open collector. Erik
Thank you for your response. For clocking I use the chip's internal clock. I have tied the reset high. I do not use push-pull, I will look at this more carefuly. I have checked power and ground. Can you tell me what IIFC pins are? Thanks.
thumbs Not IIFc but IIC Erik
Thanks, they are. I will spend some time probing around the board, since it sounds like the issue may not be the software. Thanks again.
forgot one: do you have pullups (I use ik) on the IIC wires, missing those resistors MAY work with an emulator and not with a chip. Erik
Yes I do. Thanks.
Is it possible that I am setting up uvision incorrectly? Once I want to burn an eeprom which I use the MCB900 and flash to do, what do I need to change on my target setup, given that the setup is for the emulator? Thanks
