bank ...
I've a application using
* Large Memory Model
* Large Code Rom
and I'm using LX51 linker, when I compile my project I'm getting IMPROPER FIXUP problems in some segments.
I've found insctruction caused to this error, It's a LCALL instruction
069C 120000 E LCALL micro_search_fine
My application have 4 banks, caller function is at bank1 called function is at Bank0.
I've included at my project L51IBANK.A51 file for variable banking. I saw that compiler creat at common area a inter bank call table.
000190H 00087FH 0006F0H BYTE UNIT CODE ?BANK?SELECT
so
I dont use
a user defined bank mechanism.
And I'm receiving some other improper fixe-up at
the same instruction LCALL
which call another function from another bank. But there exist another funtion making an inter-bank function call
 without
improper fixup
