hi all, I am testing the working of fast interrupts. I have set the interrupt as CACHED. what is wrong with the following code?
void main(void) { uwBank_set = 0; FINT0CSP = 0x8F01; FINT0ADDR = 0xFF00; GPT1_vStartTmr(GPT1_TIMER_3); while(!uwBank_set); GPT1_vStopTmr(GPT1_TIMER_3); }
Thanks for information, it came from a nice cooperation with Infineon and KEIL's support team. Good luck with XC166 Stefan
yes, Now I am getting it correct.
Hi, did you have a look (?) at http://www.keil.com/support/docs/2582.htm XC166: Using Fast external interrupts Stefan
