I've a simple question. I'm trying to send a 32-bit word serial on an AT89C1051U. I'm trying to use a for loop and send the LSB each time, and then shift to the right every iteration. This, in theory, would allow me to send each bit no problem. Here's the code I tried, but I kept getting array problems.
for(n=0; n<32; n++) { p3 = y; y >>= 1; }
There's no array anywhere in that snippet. It usually helps if you cut-and-paste the exact source code from your project. When people rewrite it into an example, sometime they erase the problem. Exactly what error messages are you getting from the compiler? (And lint?) Is "p3" supposed to be a pointer? In that case, you need some sort of dereference (*p3 or p3[...]). Is it perhaps a bit variable? Either way, you probably should make it more clear that you are extracting the LSB from y, something like bitToSend = y & 1;
sorry, here's the whole code:
#include <reg51.h> unsigned long a = 0xFA6; unsigned long b = 0xB82; unsigned long c = 0xE2A; unsigned long d = 0xC30; unsigned long y; unsigned long sum; unsigned long delta; unsigned long n; sbit pin37 = P3^7; int main(){ pin37 = 1; while(1){ sum = 0; delta = 0x9E3779B9; n = 32; y = P1; while(n-->0) { sum += delta; y += (y << 3) + a^y + sum^(y >> 6) + b; } for(n=0; n<32; n++) { y >>= 1; pin37 = y[1]; } } }
for(n=0; n<32; n++) { pin37 = (bit)(y & 1); y >>= 1; }
Thank you very much, that did exactly what I needed it to. Hope someday I can return the favor. Enjoy your day everyone :)
