I have a program which works fine in small memory model. The program is growing beyond the 2K boundary and I want to switch to the Large model. When I switch to large model, the program stops working. I also tried it with a working code which is less than 2K. The only thing I do is set the memory model to large 64K code. Am I supposed to do anyting else? Thanks. -sam
My code is larger than 2K. It is going to be close to 4K. The eval is supposed to be good up to 4K. What are my options? Thanks.
if you are using the eval version, you may get in trouble since the eval is limited in code size and location. Also using the LARGE model with a derivatives as small as the LPC does not make sense, why are you even attempting it? Erik
You don't need to change the memory model as all this affects is the default memory space used for variables. Generally speaking you should always use the small model. You do need to change the 'code ROM size', however. I suspect the reason your code no longer works is because you have changed the memory model and your variables are now being located in non-existent external RAM.
I forgot to mention that it works with the epm900 emulator, but once I burn a part (philips lpc932) using the mcb900, the part does not work. Thanks -sam
