I have a program which works fine in small memory model. The program is growing beyond the 2K boundary and I want to switch to the Large model. When I switch to large model, the program stops working. I also tried it with a working code which is less than 2K. The only thing I do is set the memory model to large 64K code. Am I supposed to do anyting else? Thanks. -sam
"LARGE" does not make sense, "ROM LARGE" might. And he does post "memory model" The 932 has about the same amount of RAM and XRAM, thus memory model LARGE does not make sense. Erik
""LARGE" does not make sense, "ROM LARGE" might. And he does post "memory model"" Yes, and then he posted: "Problem solved. My bad, confusing memory model with code size. Thanks" Please read the thread carefully from the beginning.
OH, missed that.
Sorry for all the confusion. I was setting memory model to large in order to use more than 2K of ROM. However, this affects the ram size as well and tries to use non-existent ram (external ram). So the program would work on the emulator and not when I burned a chip. I guess the emulator has the external RAM. Instead I need to set the ROM size to either compact or large and leave memory model as small. I realy appreciate everyone's help. -sam
