Could anyone check my coding here. I'm trying to create a word search program. I have a 6x6 word board and a file that contain 3 word in the list 6x6 word baord: A E N T E R A P A E A A E N P E R S A D A L A F A F A F E F wordlist: ACE APPLE ENTER and i'm suppose to search for the word in 8 directions public void readWord () { word1 = new char [3][]; puzzle1 = new char [6][6]; finalWord = new char [6][6]; int i,j; String s,p; for (i=0; i<word1.length; i++){ //For loop to read in search words s = puzzle.readString(); word1[i] = s.toCharArray(); } for (i=0; i<6; i++){ //For loop to read in jumbled puzzle p = puzzle.readString(); puzzle1[i] = p.toCharArray(); } //Search private boolean found1(int i, int b) { for ( int k=0; k<word1[2].length; k++) { if(Character.toUpperCase(word1[2][k]) != puzzle1[i][b+k]) { return false; } } return true; } //Forward search method private void forward(){ boolean tmp = false; for (int i=0; i<puzzle1.length; i++) { for (int b=0; b<=word1[13].length; b++){ tmp = found1(i, b); if (tmp) { for (int k=0; k<5; k++) { msg.writeChar(puzzle1[i][b+k]); //foward search } } } }
That code's illegible! Please read the instructions about posting code, and then do what it says! (instructions are immediately above the 'Message' box when you make a post!)
the code only works when i put [13], if i put like a variable it doesn't work at all. thanks!!!
And what in god's wide world, if I may be so bold to ask, made you think that this forum was the right place to ask a question about, of all things, Java programming?
