Howdy, i am using Keil's 'hello.c' program on a C167CR-LM, Phytec dev board. It outputs 'Hello World' to the serial port using printf. This works fine if i simulate it in uVision. But when i load it into flash and run it, it outputs garbage. I've tried hyperterm and matlab to capture input on PC end - output is just spaces or all the same char. Sometimes it correctly outputs the first char only, followed by garbage. I've looked at Tx pin on output from board with oscilloscope, and it just transmits continuous RS232 signals indefinitely. Other programs like blinking LEDs work fine in hardware. Ideas???
No, it's disabled. However, i downloaded another 'hello world' program from the phytec website, which has a newer version of the start167.a66 and it works fine. There's no difference in the hello.c source code, so it must have been something in the above file. Strange...
Might be a problem with the WATCHDOG. Is the watchdog enabled in the START167.A66 file? Reinhard
