Dear Friends, How to create a delay loop in C51.Say for example I need a delay loop for 35mS.How to do this.I tried a code taken from this forum.It is void delay(void) { unsigned long msdl; msdl = 35L * 1000L; while(--msdl) { _nop_(); } } Logically I think it should produce a 35mS delay code.But When I see in the Performance Analyzer window the delay produced is 0.547275 seconds. Can anybody help me in solving this problem. Thanx in Advance
It is very difficult to achieve accurate delay loops in 'C'. I've no idea why you think the code you have posted would produce a 35ms delay. You really need to use a timer if you need an accurate delay.
It is very difficult to achieve accurate delay loops in 'C'. I've no idea why you think the code you have posted would produce a 35ms delay. You really need to use a timer if you need an accurate delay. It is impossible to achieve version, release, optimization independent accurate delay loops in 'C'. You really need to use a timer or a routine in assembler if you need an accurate delay Erik
Also, just think of the 35mS that your program would be doing nothing (except maybe interupts). Andy
Also, just think of the 35mS that your program would be doing nothing (except maybe interupts). Andy Sorry, ment controller, not program
"(except maybe interupts)" If you allow interrupts in a delay loop, then what little hope you ever had of accurately predicting its timing disappears completely!!!
I often find it useful to have a delay loop that delays "at least this long", but where I'm not terribly concerned with the upper bound. Other times, I need a loop that waits exactly some amount of time. Different requirements call for different solutions. For times on the order of 35 ms, hardware timers are often useful. I find cycle-counting software schemes more useful for very small intervals. For the OP's question, you also have to account for the loop overhead. 35000 _nop_s will indeed take 35 ms (assuming 1 usec / instruction cycle). But it also takes time to decrement the loop counter, jump, and so on. Particularly with a 32-bit counter, this takes a significant amount of time compared to just the NOP instruction. The usual method is to normalize the timing loop by measuring (or calculating) the overhead for each trip around the loop, and adjusting the number of loops accordingly. As Erik points out, this normalization depends on details of how the code generator happens to work, and thus you might have to renormalize every time you change compilers or optimization levels. Write the delay loop in assembler, and at least you remain in control of exactly which instructions get used.
Look at Keil's AP note 105 for C51. It's an interrupt driven timer example. Just don't use the example call to delay(). It's little more than do nothing loop but the example is a good start for a timer tick that you can test in you program.
you might have to renormalize every time you change compilers or optimization levels. A litle detail, often forgotten: you might have to renormalize every time you upgrade the revision of your compiler, change compilers or optimization levels. Every compiler manufacturer (hopefully) strives to make the generated code more efficient for each revision. E.g. Keil could go through all generated compares and see if CJNE/CY or SUBB was the fastest approach. None of that would constitute optimization just a better conversion. Erik
"you might have to renormalize every time you change compilers or optimization levels." Or memory model, or... A 'C' compiler gives you absolutely no guarantee whatsoever that any particular source line(s) will generate any specific sequence of machine instructions [1]. eg, the compiler may choose to put certain variables into registers. You have no control of this choice. It is quite possible that apparently unrelated changes elsewhere in your code could affect the compiler's choice of which variables go into registers. If this means that your delay loop counter moves from XDATA to a register (or vice-versa), the delay could easily change by a factor of two or more! I'm sure there are other examples - especially at the higher optimisation levels. [1] Apart from specific language extensions like _nop()_
the revision of your compiler That's what I mean by "change compilers". If it's a different .exe file, even from the same vendor, then the code generated may well not be the same. (Simiarly, if you're serious about configuration management, you don't just need version control on your source code; you've got to version control the entire toolchain as well, so that you really can go back to version 1 and rebuild it with the exact tools you used originally. Rebuilding the same source with a newer compiler may not produce the same binary you shipped out to the field two years ago.)
"if you're serious about configuration management, you don't just need version control on your source code; you've got to version control the entire toolchain as well" And, of course, "the entire toolchain" includes the OS to run it on! Just look at the number of threads here where people are struggling to get some ancient Keil version (written for MS-DOS v3.3) running on XP or something!! :-0 eg, http://www.keil.com/forum/docs/thread4969.asp then you might also struggle to find a 286-based PC to run it on... I think some military projects have entire development systems (complete hardware & software) in store in case changes ever need to be made...
Dear Friends, Thank you all for the useful reply.I am a beginner to this KEIL.I dont know how to get a delay loop for the 35ms.I dont need a accurate value.I just want to use this delay for button debouncing.Please guide me to generate a delay loop in c51.Sorry for stealing your valuable time.
"I am a beginner to this KEIL" None of this is specific to Keil; you cannot directly predict the execution time of any 'C' source line compiled with any 'C' compiler for any target! "Please guide me to generate a delay loop in c51" Please re-read all the preceding replies: You cannot predict the execution time of any 'C' source line! Therefore, trying to create a known delay in 'C' source code is folly! You need to write the loop in assembler: then you know exactly what machine instructions will be used, and you can calculate exactly how long they will take to execute. The timing details for each instruction will be given in your processor Datasheet. The times will be given in terms of Clock Cycles, so you will also need to know your clock frequency. To easily make an assembler function callable from C51, proceed as follows: 1. Write a "skeleton" of the function in 'C'; eg,
void wait_35ms( void ) { // Nothing! }
"I just want to use this delay for button debouncing" I think a timer-based approach would be far better for this application. Do a bit of work with your favourite internet search engine, and I'm sure you'll find plenty...
""you might have to renormalize every time you change compilers or optimization levels." Or memory model, or... A 'C' compiler gives you absolutely no guarantee whatsoever that any particular source line(s) will generate any specific sequence of machine instructions [1]. eg, the compiler may choose to put certain variables into registers. You have no control of this choice. It is quite possible that apparently unrelated changes elsewhere in your code could affect the compiler's choice of which variables go into registers. If this means that your delay loop counter moves from XDATA to a register (or vice-versa), the delay could easily change by a factor of two or more! I'm sure there are other examples - especially at the higher optimisation levels. [1] Apart from specific language extensions like _nop()_" For the code given these issues can mostly be addressed by: 1) Compile the delay code at optimisation level 0. 2) Explicitly specify the memory space for your variables. 3) Declare all variables as volatile. 4) Write your own routines to increment and compare multibyte data types (hint: use a union) to avoid library calls. It would be an interesting exercise (well, I think so anyway) to run some tests along these lines using a really old version of the compiler and the latest. I'd put a really small bet on that one could come up with an implementation that would compile to the same code. I occasionally use the above techniques when I need to make sure that I don't see a large change in execution times between builds, and sometimes to generate faster code than the compiler. Yes, really. All: Please note, before responding with angry posts full of uppercase and aggressive HTML, that I do in the general case recommend the use of timers and assembler for delay loops.
