Hi all, My goal is to put a few constants in the code segment at compile time so they are stored in the program flash when the SiLabs 'F122 is initialized via JTAG.
const UCHAR code ucTBD = TBD_VAL;
const UCHAR code ucTBD _at_ 0x6000 = TBD_VAL;
typedef unsigned char UCHAR; #define TBD_VAL (0x00)
UCHAR code ucTBD = TBD_VAL; some_other_variable = ucTBD; // The compiler will generate a MOVC instruction here!
C51 doesn't let you use both _at_ and an initializer for the same variable. This feature is often requested on the board. You can use the initializer in the compiler, and then use the linker to place the variable where you want it. See the "Segment And Memory Location" section of the linker manual. You may need to declare the variables you want to manually locate in a separate C file to ensure that they get their very own segment name.
Thank you both for your swift replies. The separate segment name was the ticket. There's a warning about "UNCALLED SEGMENT, IGNORED FOR OVERLAY PROCESS" but the data are there right where the linker put them. To answer A.W. Neil's questions: 1. MOVC A,@A+DPTR 2. It doesn't need to be at a fixed address. 3. I just want it to be where I'm comfortable erasing it, that is, at a known address above 0x0200. 4. It can use a symbolic name but I want to reference it by address for bootloader reasons.
John; I use starup.a51 to set these code bytes. About one third down the page you will see CSEG 0. I set CSEG 0yyyh then DB byte1 DB byte2 etc. CSEG 0 Not C but you can force any init bytes to any code address that is required,
Al, That seems more direct. Thank you all for the fast and expert advice. John
"This feature is often requested on the board." A common reason is for a version code - placed at a known location so that it can easily be found on a PROM programmer. However, I don't see anything in the original post that actually requires fixing at an absolute address. Perhaps John could explain?
"3. I just want it to be where I'm comfortable erasing it, that is, at a known address above 0x0200. 4. It can use a symbolic name but I want to reference it by address for bootloader reasons." Aha! You didn't mention a bootloader - you said you were loading via JTAG. So, surely, what you want is not to fix the location of this particular variable, but to prevent the Linker from placing anything below 0x2000 (or whatever). Note that the Linker will slot stuff into any gaps in the vector table if it can. The vector table is not sacrosanct - it's just another bit of CODE space as far as both the Linker and the processor are concerned.
"Not C but..." Make them PUBLIC, and they are accessible from 'C'
Good point Andy. Thanks for the reminder. Bradford
