const DATA at absolute address in CODE seg
Hi all, My goal is to put a few constants in the code segment at compile time so they are stored in the program flash when the SiLabs 'F122 is initialized via JTAG.
const UCHAR code ucTBD = TBD_VAL;
seems to work but I'd like to put the data at a known address so I can read it explicitly with a MOVC-type flash read. But
const UCHAR code ucTBD _at_ 0x6000 = TBD_VAL;
is unacceptable because an absolute specifier is illegal.
Without the "_at_", the linker puts the data down with the ISR vectors but I need it to reside in flash space that I am comfortable modifying.
It seems to work if I declare ucTBD inside a function and assign an absolute location to that function. Is that an acceptable and reliable method?
Thanks in advance for any advice,
John
Ref:
typedef unsigned char UCHAR;
#define TBD_VAL (0x00)
