Quite simply, how can I tell how much free memory I have in a memory pool? I've created a memory pool, initialized it with init_mempool and use malloc & free finctions for memory management. Is there a simple way to find out how much memory is still available to be allocated? I have a fairly dynamic application and I would like to insert some degugging triggers if memory gets low. I thought of simply using malloc to request a block of say 200 bytes and then free it again. Could do this once a second and generate a low memory error if it fails. Seems a bit clunky, is there an easier way that I have missed?? Thanks, Bryan Green.
