I am working with a Cypress FX2 based board. There are 5 endpoints (BULK) that I use. Endpoint 1 and 4 are used for sending data from PC to FX2. Endpoint 2 and 6 are used to send data from FX2 to PC. Endpoint 8 is to be used for reset. Endpoint 1 is used for Initiating communication with the PC. The firmware is polling for the a flag which is set by the ISR for this endpoint e.g. Polling function: void poll_func(void) { if( EP1_Enabled) { resetFlag = 0; //clear the reset process_command(); EP1OUTBC = 0 ; // re-arm endpoint 1 OUT SYNCDELAY; EP1_Enabled = 0; } } ISR: void ISR_Ep1out(void) interrupt 0 { // tell polling software we have new data EP1_Enabled = 1; EZUSB_IRQ_CLEAR(); EPIRQ = bmEP1OUTIER; } The process_command() processes user requests and reads some data (with timeouts) of FPGA and fills up output endpoint 82Hnd arms it as below: { /* Fill 32 bytes in ep2 buffer Maximun time allowed = 50 millsec. */ receive_wait(32, 50); EP2BCH = 0; // arm endpoint 2 IN EP2BCL = 0x20; /* if both buffers are still committed to USB, wait around until one of them is free */ while((EP2CS & bmEPFULL) && !resetFlag ) ; } The ISRs for EP2 and EP6 are empty. i.e. void ISR_Ep2inout(void) interrupt 0 { } The ISR for EP8 used for reset is as below: void ISR_Ep8inout(void) interrupt 0 { EP8BCL = 0x80; //re-arm endpoint 8 SYNCDELAY; resetFlag = 1; EZUSB_IRQ_CLEAR(); EPIRQ = bmEP8IER; } The PC sends data on EP1 and then starts waiting to get data back on EP2. In some conditions, I want to use receive_nowait() instead of receive_wait() i.e. I want to do receive_nowait(32); so that this call would become a blocking call and firmware control would come out of this function only after 32 bytes are received or if the resetFlag is set to 1. The PC application spawns a thread and sends data on EP1 and then it waits on data from EP2 (since receive_nowait() is blocking. Now if I have to set the resetFlag, I send data on EP8, which should work. But it gets queued, till I come out of receive_nowait() and arm EP2. Only after this, I see that resetFlag is getting set to 1. I seems like interrupts get disabled, while I am handling any other interrupt.I tried setting EA(IE Register bit 7) to 1, EUSB (EIE Register Bit 0) to 1 and USBINT (EXIF register bit 4) to 1 How do I fix this? Any ideas would be greatly appreciated. Thanks Dave
Any suggestions? Thanks
