banking and variables
hi all
I've an array located at code some segmet at adress 0x3125H and a pointer at xdata which points to it.
this program contains 4 banks, when i run my software I see that pointer points to correct code address but I cant see correct values at this address.
I've checked whether I use this pointer in an segment at the same code bank. I use pointer always at segments located at the same code bank.
plus
to use this variable at different segment (placed in a different code bank)
what I 've to do?
thanks all
