I got stuck up while interfacing LCD through KEIL C compiler.The .asm program which works fine,is not working when I try to compile it , after converting into C. Can anybody give C code for interfacing LCD through 89C51
Why not just use the working assembler code?
what is all this "convert asm to C" stuff? If you have a perfectly well functioning asm code why convert it??? I have some V.O. assembly routines I have modified slightly to make them callable by C, that does make sense to me. Converting the whole shebang to C does not. Erik V.O. = Cognac designation "Very Old"
