bad cpu/memory?
Hello everyone, this time I doubt the problem is caused by my (lack of) c skills, as the issue occurs inside the standard keil STARTUP.A51 file :)
Have a look at this assembly code;
I expanded it to be more "granular", so as to see exactly which partial instruction is failing:
IF IDATALEN <> 0
MOV R0,#IDATALEN - 1
IDATALOOP:
CLR A
MOV @R0,A
DEC R0
MOV A,R0
JNZ IDATALOOP
; DJNZ R0,IDATALOOP
ENDIF
This piece of code sometimes stalls (seemingly at random); if I step into it with the uVision debugger, I see the DEC R0 instruction decrementing R0, then the MOV A,R0 puts the old(!) value of R0 into A.
To me that says faulty hardware. [confirm/deny]?
my IDATALEN is 80H, and i'm using a 8252.
Cheers,
Barry
