Dead Time problem
I use the CAPCOM6 unit to generate a PWM signal. To use this signal for a motor I need a dead time between the inverted and the non inverted signal. I think that a initialized the registers correct, because the non inverted signal is correct. The inverted signal makes problems. It is not correct.
