hi I compiled an example of uvision2 .I have just changed name and I've opened new project when I've compile it,I couldnt find any hex file but I found .lst .opt .Inp. can you please inform me about this
Did you check the 'Create a Hex file box'?
the thing is I can't find any box which is called create hexor sth like that. there is an option which is called build target.isnt it enough for creating a hex file
