Hello Friends, I defined an SPI interface, µc as master and only one salve, I cannot see clock generating at SCK0...I tested with Oscilloscope....Please you check the code ..and where am I doing error ??? void init_spi(void) { S0SPCCR = 0x08; /* SPI clock */ S0SPCR = 0x60; /* µc as master, LSB as first bit, CPOL = 0, CPHA = 0 */ IOSET1 = 0x00010000; /* Blink LED */ } int init_spi_write(void) { S0SPDR = 0x01; /* Write Data Address to SPI */ while ((S0SPSR & 0x80) == 0); /* Wait Until SPIE bit is set */ IOSET1 = 0x00100000; /* Blink the LED */ return (S0SPSR); /* When SPIE is Set, read the Status register*/ } int init_spi_read(void) { unsigned int dummy; dummy = S0SPDR /* Read the value from SPI */ while ((S0SPSR & 0x80) == 0); /* wait until SPIE bit is set */ IOSET1 = 0x00200000; /* Blink the LED */ return (S0SPSR); /* When SPIE bit is set read Status Register */ } int main (void) { initial_serial(); /* Initialize the Serial Interface with UART */ PINSEL0 |= 0x00005500; /* SCK0, MISO, MOSI for SPI0 enabled & SSEL*/ IODIR0 = 0x00003C00; /* P.10.. P.13 defined as outputs */ IOSET0 = 0x00001400; /* p.10, p.12 high & P.11, p13 are low to select CS*/ IODIR1 = 0x00FF0000; /* Define P1.16 to P1.23 as outside */ IOCLR1 = 0x00000000; /* Turn off LEDs, you can check your flash is working or not */ init_spi(); /* Initialize the SPI Interface */ init_spi_write(); /* Write the data to SPI */ init_spi_read(); /* Read data from SPI data register */ } I made High on SSLE ...P0.7 to 3.3v........Still I dont see any clock generating st SCK0 nor any signal at MOSI or MISO....... I am waiting for your replies, Thanks in Advance, Sridhar
