Considering VCS. Any recommendations pro/cons from among the systems supported by uVision?
This has been discussed before - try a Search. QVCS: http://www.qumasoft.com Never bothered to try "integrating" it into UV2, though - not sure what the benefit would be...
Right. I did search. The posts I found didn't cover my question exactly, hence my message. In the case of qumasoft, what are the pros and cons for your recommendation? Why might one choose it over a different system?
I use Perforce. It is a very high integrity version control system. It is free for 2 users/client workspaces, else you have to pay for it. I don't know if it integrates with Keil though, for I don;t find a svcs file, but I do know it does integrate with CodeWarrior for which I am very familiar and use everyday. Anyway, even if it does not integrate directly with Keil you will see a R/O in Keil if you can not modify a file when it is open in your project. So just close it. Open for write in Perforce and then re-open in Keil. There is a Microsoft format that Perforce adhears to so if Keil does then contact Perforce directly. I have not approached them yet for I am satisfied with this little irritation. http://www.perforce.com If you need a little advice on setting up say so offline. A fabulous svcs.
"Why might one choose it over a different system?" Compact, simple, cheap - and it works!
