this "extract to show" compiles with the warning. I definitely do not want the overhead from mspace ignored. What am I missing in making this mspace dependent i.e VFcPtr always code.
here void VFDcdatLgt(unsigned char code VFcPtr[], VFcCcnt); unsigned char code VFinit[] = {0x1b, 0x40}; unsigned char xdata GCXvfdBuf[40]; void main (void) { VFDcdatLgt(VFinit, 2); // in initialize } /*- end main -*/ here void VFDcdatLgt(unsigned char code VFcPtr[], VFcCcnt) { unsigned char VFDCtemp; for ( VFDCtemp = 0 ; VFcCcnt !=0 ; VFDCtemp++, VFcCcnt--) { GCXvfdBuf[VFDCtemp] = VFcPtr[VFDCtemp]; } }
I presume this is a C51 question? I seem to remember seeing something like this sometime in the distant past... What if you try:
void VFDcdatLgt(unsigned char code *VFcPtr, VFcCcnt)
How about: void VFDcdatLgt(unsigned char code* VFcPtr, VFcCcnt); instead? You can't specify an mspace for a parameter, but you can for the target of a pointer. I'd also suggest void main (void) { VFDcdatLgt(VFinit, sizeof(VFinit)); // in initialize } /*- end main -*/ Or, more likely, a #define for the size of the array. It's rare (at least for me) to have a use for an array of unknown size since so many routines wind up needing to know the size. Might as well have a constant for it. And supplying a explicit size lets the compiler / lint check the initializer for completeness, which helps when changing the size of the array.
I'd also suggest void main (void) { VFDcdatLgt(VFinit, sizeof(VFinit)); // in initialize } /*- end main -*/ as stated this is a cut down reduced etc 'demo of problem' it does in no way demonstrate my writing/coding style I'll try the pointer, but still think that what I did should work. Thanks, Erik
FYI it works with pointers, it works with char, int etc; there is no reason it should not work with arrays. Keil, please take note. Erik
"it works with pointers, it works with char, int etc; there is no reason it should not work with arrays." I think there probably is - as Drew said, "You can't specify an mspace for a parameter, but you can for the target of a pointer." (my emphasis) I think when you defined your parameter as an array with the 'code' mspace, you were effectively saying, "this parameter is passed in code space" - which obviously can't happen When you use the pointer version, as Drew & I suggested, you are saying this parameter points to an address in code space - which is quite a different thing. Although pointers & array names are very nearly equivalent in 'C', there are still subtle differences - and this is one of those places where it matters! In ANSI-speak, an array name cannot be an lvalue; ie, it cannot appear on the LHS of an assignment. As mentioned earlier, I seem to remember falling over this before - and I think I used an explanation on the lines of the above to convince myself of what was going on!
A further thought: "You can't specify an mspace for a parameter, but you can for the target of a pointer." Similar to the way that you can't specify diffenent mspaces for the members of a structure, but a structure can contain pointers to different memory spaces!
anyhow: void func(array[]) passes a pointer to the array, not the array itself to the function. So the Mspace parameter specify the location of the array, not the pointer. so void func(array[]) void func(*array) are equivalent, the only difference being that one is clearer than the other. Thus, both formats should accept mspace modifiers. Erik
I imagine it has some thing to do with the following: char code *ptr_to_code is a pointer in the default mspace that points to Code space; char code * code code_ptr_to_code is a pointer in Code space that also points to Code space. char code code_array[] is an array in Code space. You can use the name "code_array" as a reference to the location of the array, but it isn't exactly a pointer - it is not a separate variable stored somewhere. No doubt it's somewhere in this extra possibility of specifying both the location of a pointer and it's pointed-to mspace that it all falls down?
"void func(array[]) void func(*array) are equivalent, the only difference being that one is clearer than the other." But, I suspect, the opinion as to which one is the clearer is a subjective one...? ;-) Personally, I say the "func(*array)" is clearer as it describes exactly what is actually passed - a pointer - and gives no room for anyone to think that the whole array might actually be passed. But I guees that you find "func(array[])" clearer...? ;-)
1)Personally, I say the "func(*array)" is clearer as it describes exactly what is actually passed - a pointer 2)But I guees that you find "func(array[])" clearer...? ;-) 1) show what is passed 2) show what is used a proverb "some like the mother, some like the daughter" describes our "argument" rather well. Erik
void func(array[]) passes a pointer to the array At the risk of being called a pedant: that's not exactly true. What this passes is a pointer to the first element of the array, not the array itself. The difference is that you can't modify the array itself through that pointer, but only its contents. I suspect the actual difference is in the syntactical scope of the 'code' keyword. In a pointer, there are two things 'code' can modify, depending on where exactly you place the keyword: the memory space of the pointer itself, or of what it points to. For the array-style declaration, this distinction would appear to be impossible (there's no * you can stay to the left or right of).
"At the risk of being called a pedant..." You're a pedant! there. ;-) trouble is, we're into the level of detail now where it all gets very pedantic... "I suspect the actual difference is in the syntactical scope of the 'code' keyword." yes - that's the kind of thing I was trying to get at. "For the array-style declaration, this distinction would appear to be impossible (there's no * you can stay to the left or right of)." Yes: because, with an array, there is no pointer to be stored anywhere - you just use the name, and the compiler knows implicitly to insert the address at compile time.
Note that the example at the end of the online description of this message is incomplete: http://www.keil.com/support/man/docs/c51/c51_c258.htm For the full description, see the PDF manual.
