hi all, i'me running an application from external flash, and i would jump to internal flash to perform the external flash update. I've read something on the datasheet, but seems not so easy. I think i need some electical modification on the circuit.. Some short introduction on the better way to go will be very appreciated. thanks Angelo
What you do (or don't) have to do in terms of modifying your hardware is completely beside the point of this forum. That's between you and your hardware to settle --- Keil C51 has next to nothing to do with it.
Hi, Check a microcontroller forum such as Electro Tech Online (http://electro-tech-online.com/viewforum.php?f=11&sid=6f9c9b1f915e35e6e9dc9fc79afa44cd). You may find hardware help there.
