Hello all, I want to interface 8051(actually, 89c51) to LCD display (any), Keypad and also to temerature sensor+ADC assembly. I would be glad if someone please helps. Regards, Ashish.
Look in the downloads area. Look in the examples that install with the Keil tools. Look for examples, application notes, etc on the support sites of your chosen sensor & ADC manufacturers. Use your favourite internet search engine. Or, if you want someone to do it all for you: http://www.keil.com/condb/
hi Ashish, Decide to which port you are going to connect the LCD and to which port you are going to connect the Keyboard.Let us know if it is PS2 or keymatrix(telephone) type. more after you reply.... Rutu
hello..can u help me to find..programe for keyboard... how it detect by using lcd?
hello..can u help me to find..programe for keyboard... how it detect by using lcd? 1) when you are asking micro for the answer, why do you not e-mail him directly 2) a LCD can not "detect" anything, it display what you feed it. Erik
if somebody here completly,properly,clearly tell the interfacing of lcd,adc and temperature sensor wiyh 8051 thankx
urgent help needed: hi everybody im in problem that i have to submit my project if somebody here completly,properly,clearly tell the interfacing of lcd,adc and temperature sensor with 8051 microcontroller alongwidth proper code(in asp) thankx
"have to submit my project" Note the emphasis there: it's supposed to be your project that means that you are supposed to do the work yourself So, how far have you got with it?
Or perhaps this is what you want: http://www.echeat.com/
