External memory in SPC3
Dear all,
The Siemens Profibus Controller (SPC3), connected to a T89C51RD2 via P0 (multiplexed) and P2, has in its first few addresses registers/latches which I have to set in order to start using it. I believe the SPC to be wired to begin at 0x8000, as the output from P2.7 is inverted before being put into SPC3.
In the options for target, I've set:
memory model: small
code rom: small
off chip xdata memory: start: 0x8000 size: 0x600
The rest of the options are left blank.
In STARTUP.A51 I've set:
XDATASTART EQU 8000H
XDATALEN EQU 600H
and in code:
AUXR = 0x0E;
Suppose the address of the register that i'm trying to read is 04H in the SPC. Why does putchar(XBYTE[0x0004]) (or putchar(XBYTE[0x8004]) for that matter) not work? (ie. it outputs the value of the address, '04', and not its contents) I later used a for-loop to output XBYTE[0x0000] through to XBYTE[0xFFFF], which always seem to return the last 2 hex-digits of every address.
I've also set the xdata in 'options for target' and Startup.A51 to 0x0000 with size 0x000 to the same effect.
Did i miss out or misunderstand something? Any help would be greatly appreciated.
