Hi, I am using Cx51v7.20 I have declared a table in battery backed far data memory as an unsigned int table.
unsigned int far fireCalibrationANALOG_FIRE_LINES] _at_ 0x5F0050;
unsigned int far levelTables[FLTS_CAL_LEVEL_MAX][ANALOG_FIRE_LINES] _at_ 0x1FC00;
levelTables[FLTS_CAL_LEVEL_SV_OFFSET][adChCount] = svCalibration[adChCount];
Might be a problem of the functions in the file XBANKING.A51. These are fully user configureable, so please check if they are OK.
