DS80C400 B1 and Keil C51
The DS80C400 revision B1 chip has a bug in the DIV AB instruction which can manifest if ACC is loaded after B prior to the DIV.
The http://www.keil.com/support/docs/1977.htm page suggests that C51 generates contiguous mode code that works with earlier versions of the 390 which have the same fault.
Is it safe to assume that C51 also generates correct contiguous mode code for the 400 too?
