I am testing a routine with serial interrupt and I notice that the value is not transferred from SBUF. I notice this in uVison debug. What's happen? Please help me. follow my parcial intr routine
if(RI) { c = SBUF; //<-- here is my problems RI = 0; if (istart + ILEN != iend) { inbuf[iend++ & (ILEN-1)] = c; } }
Erik's follow-up for my long-winded post with the couple sentences from the datasheet doesn't seem to me to be designed to do anything other than humiliate the poster and that seems unfortunate. 1) no intention to "humiliate", I never have any desire to do so. I may be direct in my statements, but have never tried to humiliate anyone. I may not be very "sensitive" to questions that do not fully describe the background, but I will try as hard as I can to overcome a language barrier (as long as it is not SMS). 2) "the bible" explain SBUF from the opposite viewpoint (2 registers with one address, not one address with 2 registers), thus might be understood when approach 1 is not. 3) If there was any "intention" other than 2) it was to show that answers such as these can be foun in "the bible" Erik
Alright.. you found it. Here's the real point of my test: this time don't take out your Bible. Now tell me what the context of that passage is (i.e. what's going on, what's being talked about)? I understand that eventually people need to develop an instinct to just sit with the datasheet for their chip open and refer to it as needed, but I know that when I started there were plenty of things I didn't understand even after reading them, until I hacked and tried and finally got something to "work." I'm just trying to describe things for the OP in a bit more detail than might be included in the documentation. I know it's a simple concept, but there's also clearly a language barrier for Marcio with regard to English. Erik's follow-up for my long-winded post with the couple sentences from the datasheet doesn't seem to me to be designed to do anything other than humiliate the poster and that seems unfortunate.
"I could see how someone could read the entire text and somehow miss that one." The reference is Numbers chapter 2, verses 29b-30. I see what you're saying, but I just tried it: it took just over 5 minutes to find it - and that included fetching my Bible and leafing through the pages. I have read the whole text, and didn't know that verse by heart (no surprise there, then!) - but I had a good idea where it might be found (Numbers). That's the point: it's not expected that you know the 8051 "bible" by heart - but it is expected that you make it your first point if reference for any query. Plus, it's a lot shorter than the real Bible - and, being PDF, has a Search facility... And, for this particular case, it also has diagrams to illustrate the point!
And a quote from the actual Bible says: The leader of the people of Naphtali is Ahira son of Enan. His division numbers 53,400. but I could see how someone could read the entire text and somehow miss that one. Go figure.
Let us try "the hortses mouth" an extract from "the bible" "The serial port receive and transmit registers are both accessed at Special Function Register SBUF. Writing to SBUF loads the transmit register, and reading SBUF accesses a physically separate receive register." Erik
Marcio, The language in your last post was very difficult for me to understand. I'll try to take it point-by-point: ...the debug do not more gave me access to see the interrupt reception routine (I think this is the normal)... I don't understand what this means. Changing the name of a variable shouldn't do anything with regard to the visibility of the ISR. When you say "the debug" do you mean the uVision simulator? When you say "when I get the appropriate line" what line are you talking about? Is this inside the interrupt service routine? Is this in your main code? What is the specific line before which you change the SBUF data? There's a very important point which several people here have tried to point out to you: SBUF is NOT a single register. It is TWO registers. One is accessed when you perform a write and a completely different one is accessed when you perform a read. So... WRITING something to SBUF has NO BEARING one what you will READ back from the SBUF. That is completely dependent on what's coming in the serial channel. So... here's what will happen with your scenario. You open the serial channel window and enter a value into the SBUF register. You then click RI to pretend that a character has been received. Your ISR runs and you execute a line like "c = SBUF" and you read zero. That's because NONE of what you've done has modified the contents of the READ version of the SBUF. I know there's a significant language barrier between us, but I hope I've made at least something clearer.
Hi, Jay! I did what you said me and the debug do not more gave me access to see the interrupt reception routine (I think this is the normal) but, I execute this step-by-step and when I get the apropriate line I write 0xAA in "Serial channel windows" and I click in flag RI I notice that the SBUF return to 0x00 hindering the comparison. Something else is wrong? Thank you Marcio Schmidt
No... what everyone here is trying to tell you (with various levels of indirection), is that the name "C" as a variable name (aside from being an extremely poor choice to begin with) is a name used by the system to represent the carry bit within the status register of the 8051. Just pick another variable name for "C" and try it and see if it does the same thing. What people are saying is that various scope issues might cause the compiler to be using the bit C rather than your variable. Of course... if you just posted the assembly generated by your source here, we could tell whether that's the case.
Hi, I think in C language it is irrelevant, isn't it? tks Marcio Schmidt
but I am realy not using the debug command. I just use the debug to execute my C program. OK, then how do you inspect the value of the variable c? Jon
Both those things make sense if c is overloaded, did you change the variable name and retry the simulation?
Tks Mr Jon, but I am realy not using the debug command. I just use the debug to execute my C program. rgds Marcio Schmidt
Hi, Mr. Barry a matter of fact the command SIN do not make my program to work, and the c = iend do not change anything. But thank you for your time. Marcio Schmidt
I am 83.42% certain that the problem here is not understanding that SBUF is not one buffer. I think that's very likely as well. Another problem is that some variable names (A, B, C, R0-R7) are overloaded. For example, if you enter A in the command window, the debugger cannot determine whether you mean your variable A or the accumulator. The same goes for B, and C (the carry), and so on. Jon
Ok, Erik! Thank you
