GNU ARM and Constructors
I'm using a LPC2129 and DKARM 1.3
I have something like this
//class declaration
class SPI
SPI(uint8 init)//contructor
//Contructor definition
SPI::SPI(uint8 init)
//Object Declaration
SPI SPI0(1);
The problem is, when I create the object the constructor should be called, what it doesn't happen...
  • I'm not familiar with the Keil ARM tools, but:
    If the object is file scope, as you show, then the compiler has to generate code to call the constructors for all such objects before main(). The C++ run-time code will have to call all such constructors after the run-time system and libraries are initialized and before main() starts.
    So, I'd suggest checking your initialization / board support package code to be sure you call all of the appropriate hooks to initialize the system.
